WiSM compatibility for a "regular" 6509 chassis (not 6509-E)
Mar 6th, 2009
Does anyone know if the regular 6509 (ios, SUP720) chassis can support WiSM modules? And if so, how many modules? The docs on the website aren't consistent, some pages state 6509E's and others say 6509's.
Average Rating: 0 (0 ratings)
Rob Huffman Fri, 03/06/2009 - 06:59
Hi Steven,
We are just getting ready to add some new WISM's to our existing WLC infrastructure, so we just went through these same "due diligence" type questions. The answers from this good Q&A doc are all very accurate :)
Q. What products support the Cisco WiSM?
A. A single Cisco WiSM occupies one slot in a Catalyst 6500 Series Switch or a Cisco 7600 Series Router. The WiSM is supported with the Cisco Supervisor Engine 720.
Cisco Catalyst 6500 Series Switch
Q. What hardware must be deployed in conjunction with the Cisco WiSM?
A. The Cisco WiSM must be deployed with a Cisco Catalyst 6500 Series Switch and a Cisco Catalyst 6500 Series Supervisor Engine 720 (all Supervisor Engine 720 versions are supported, including the Sup720-10G-VSS).
Q. Which Cisco Catalyst 6500 Series Switch chassis are supported with Cisco WiSM?
A. The Cisco WiSM supports Cisco Catalyst 6503, 6504, 6506, 6509, and 6513 switches (**enhanced and nonenhanced versions).
Check out Table 1. Number of WiSMs and Access Points Supported
http://www.cisco.com/en/US/prod/collateral/modules/ps2706/ps6526/prod_qas0900aecd8036434e.html
Hope this helps! Good luck,
Rob
stlee@vt.edu Fri, 03/06/2009 - 07:18
Thanks Rob,
I saw that datasheet and thats where the confusion sets in. The table (Table 1) only lists the 6509E, not the 6509. The other chassis (6504,'s etc do not specify E, making me think that there's something different about the 6509's). So is it safe to assume that both types of 6509 chassis' are compatible for up to 7 WiSM's?
thanks again,
steve
Leo Laohoo Fri, 03/06/2009 - 18:33
If you go to the Q & A: Cisco Wireless Services Module (WiSM) (http://www.cisco.com/en/US/prod/collateral/modules/ps2706/ps6526/prod_qas0900aecd8036434e.html) and look under "Cisco Catalyst 6500 Series Switch", you'll see Table 2 and the following:
A. The Cisco WiSM supports Cisco Catalyst 6503, 6504, 6506, 6509, and 6513 switches (enhanced and nonenhanced versions).
Hope this helps.
Leo Laohoo Fri, 03/06/2009 - 18:37
Sup720 needs Cisco IOS® Software Release 12.2(18)SXF (mono or modular).
Rob Huffman Sun, 03/08/2009 - 11:37
Hey Steve,
Yes, the bottom line here is that the WISM is supported on the 6509 or 6509E (Enhanced)
Hope this helps!
Rob
Login or Register to take actions
Posted March 6, 2009 at 6:13 AM
Stats:
Replies:5 Avg. Rating:
Views:549 Votes:0
Shares:0
Tags: No tags.
Discussions Leaderboard
