ACE Modules and SNMP
Mar 6th, 2009
Hello Team,
I was informed by out monitoring team that the SNMP traps are being sent to the SNMP servers, but that it is reporting the device names with different IP addresses.
It seems that the ACE context is sending only the device name without the name of the context to the SNMP servers.
It there a workaround for this?
Thank you,
John...
Overall Rating: 2 (1 ratings)
Gilles Dufour Tue, 03/17/2009 - 06:50
BTW, did you configure the following first :
switch/Admin(config)# logging device-id ?
context-name Include context name in syslog messages
Gilles.
jteixido@bbandt.com Tue, 03/17/2009 - 07:57
Yes, I added the command, but I still have the problem; I will reboot the modules this weekend. I am in the process of one day upgrade to A2.1.3, will the fix be in this version?
John...
