not disconnecting
Mar 6th, 2009
I ahve a cucm ver 7.0 we are testing pstn lines at the moment.
When I make an outgoing call, all is fine, if the called party then hangs up, my line is still staying active, then a announcemnt is made that "the other person has hung up" does nayone have any ideas?
Overall Rating: 0 (2 ratings)
pcromwell Fri, 03/06/2009 - 06:45
sorry, I should have said,
It is uk based with standard ISDN 30 connection.
Paul Reck Thu, 07/30/2009 - 09:07
I know it's been a few months since this call was raised but I just had a similar issue and resolved it with the 'voice call disc-pi-off' command.
Hope you found this before now.
