session 15 command which line?
Answered Question
Mar 6th, 2009
I'm in the process of configuring radius authentication on our 6509 catos switches and I'm a bit confused. When you connect to the msfc using a 'session 15' command what line is it using? I thought that it would be the console line but changes to that do not seem to effect the login process.
Correct Answer by glen.grant about 7 years 11 months ago
No its a vty connection just like a normal telnet .
Overall Rating: 5 (1 ratings)
Correct Answer
glen.grant Fri, 03/06/2009 - 07:26
