Password for make call
Mar 6th, 2009
I have installed call manager 4.1(3)sr3c, and the phone ip make logon across Extension Mobility, how i can to do that when i make any call the phone get a password.
Overall Rating: 3 (1 ratings)
Jaime Valencia Fri, 03/06/2009 - 07:35
we provide FAC and CMC to address that, you can configure one or both depending on your needs
if this helps, please rate Tue, 03/10/2009 - 19:58
Hi Java,
Is it possible to tweak the FAC timer?
Meaning, after being prompted for the FAC code, the timeout timer would want to be longer.
Thanks. Wed, 03/11/2009 - 05:19
Well, I found the asnwer to my own question.
The user enters the authorization code. The system then either waits for the FAC Timer (T302/ or interdigit timer) to expire (default 15 seconds) or for the user to press the "#" key.
Note: Since the FAC timer affects T302 timer, bear in mind that if you adjust this timer to permit more time for FAC input, it extends the time for normal calls as well.
