2600 not able to add vlan envapsulation
jasosan22
I have a 2600 and I am trying to configure subinterfaces on a f0/0 port. I read that my code supports vlan encapsulation but when I try to add encapsulation 802.1d to the interface the command is non-existant. Here is the show ver and the error message:
System image file is "flash:c2600-io3-mz.123-26.bin"
cisco 2621 (MPC860) processor (revision 0x600) with 59392K/6144K bytes of memory
Processor board ID JAD05370MLQ (1938564210)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
2 FastEthernet/IEEE 802.3 interface(s)
2 Serial(sync/async) network interface(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
Router(config-subif)#encapsulation 802.1d
% Invalid input detected at '^' marker.
Router(config-subif)#ip address 10.1.1.1 255.255.255.0
% Configuring IP routing on a LAN subinterface is only allowed if that
subinterface is already configured as part of an IEEE 802.10, IEEE 802.1Q,
or ISL vLAN.
8 Replies 8
adamclarkuk_2
Level 4
Level 4
802.1d is spanning-tree, I think you want 802.1q or ISL for your encapsulation.
802.1d
http://en.wikipedia.org/wiki/IEEE_802.1D
802.1q
http://en.wikipedia.org/wiki/802.1q
My bad. typed in d insead of q. but still
Router(config-subif)#enc?
% Unrecognized command
Router(config-subif)#?
Interface configuration commands:
arp Set arp type (arpa, probe, snap) or timeout
backup Modify backup parameters
bandwidth Set bandwidth informational parameter
bgp-policy Apply policy propagated by bgp community string
bridge-group Transparent bridging interface parameters
cdp CDP interface subcommands
default Set a command to its defaults
delay Specify interface throughput delay
description Interface specific description
exit Exit from interface configuration mode
glbp Gateway Load Balancing Protocol interface commands
ip Interface Internet Protocol config commands
keepalive Enable keepalive
llc2 LLC2 Interface Subcommands
glen.grant
Should be configured something like this.
7500(config)#int fast 5/1/1.1
7500(config-subif)#encapsulation dot1Q 1 native
7500(config-subif)#ip address 10.10.10.1 255.255.255.0
7500(config-subif)#exit
7500(config)#int fast 5/1/1.2
7500(config-subif)#encapsulation dot1Q 2
7500(config-subif)#ip address 10.10.11.1 255.255.255.0
Thanks but the encapsulation command doesn't exist. I verified that the router/code supports vlan encapsulation but it isn't allowing me to enter the encapsulation command.
Are you try to use the encapsulation command on a fastethernet interface?
HTH,
John
HTH, John *** Please rate all useful posts ***
yes it is the on-board f0/0 and f0/1
You don't have the right feature set. You have IP/FW/IDS which does not support 802.1q. IP Plus & Enterprise do. Have a look at Feature Navigator to select correct feature set for your needs -
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Jon
You are my hero!!
