If you have a concentrator with multiple active L2L tunnels, how does it know which tunnel to use when sending return traffic back to the remote end? The remote networks list? How do static routes on the box influence this?
The concentrator makes the decision to send traffic out to the corresponding tunnel based on the network list defined or on the remote network definition under the lan to lan setup. Static routes are not really needed since it will route based on the default gateway.
Learn, share, save
