WCS upgrade and HTTP port open
Mar 6th, 2009
Hello All,
I am trying to upgrade my Wundows based WCS 4.2.97.0 to 5.2.130.0.
During the upgrade it tells me that port 8 (http)is needed by WCS and being used by another application. I have tried to find out which application is using that port so that I either stop the app or service and failed.
Would anyone kow a quick way to discover/disable the app on a Win 2003 server/
thanks a lot
Bo
ericgarnel Fri, 03/06/2009 - 09:33
Do you have IIS installed & enabled?
Also, try stopping the WCS service 1st before upgrading
bghobadi2 Tue, 03/10/2009 - 08:58
Hi ericgarnel,
I am not running IIS on the server. I removed the WCS 4.2.97.0 and rebooted the server. I still get the same port hhtp (port 80) is being used by another application.
thanks
Bo
Charles Hill Fri, 03/20/2009 - 16:11
I had the same issue regarding http (80) being used during a new installation of wcs. To resolve the issue I typed "iisreset /stop" at the command prompt. IIS was my trouble.
Trending Topics - Security & Network
