can I sort traffic by browser?
Answered Question
all my network clients are configured to use a proxy server for their internet usage. I need to know who bypassed it in order to completely enforce it.
I want to see all traffic that come from the network via IE or Firefox
as step 1 I'd like to be able to see all HTTP connections going out on ports 80\443
step 2 would separate by source - IE or FF
is it doable?
Correct Answer by vikram_anumukonda about 8 years 3 months ago
regex user-agent1 "[Mm][Oo][Zz][Ii][Ll][Ll][Aa]"
regex user-agent2 "[Mm][Ss][Ii][Ee]"
class-map type regex match-any mozilla
match regex user-agent1
class-map type regex match-any ie
match regex user-agent2
class-map WEB
match port tcp eq www
policy-map type inspect http mozilla
parameters
match request header user-agent regex class mozilla
log
policy-map type inspect http ie
parameters
match request header user-agent regex class ie
log
policy-map global_policy
class WEB
policy-map INSIDE
class WEB
inspect http ie
service-policy INSIDE interface inside
logging list TEST message 415008
logging on
logging trap TEST
logging host <> x.x.x.x
you might want to send these messages to syslog server and 415008 is the syslog message number generated when http header is matched and logging config is to send those messages to syslog server.
Keep this link, it might come handy as it gives you the complete break-up of a http request. _http://djce.org.uk/dumprequest
This is not a very optimal solution but will get you started.
vikram
Overall Rating: 4 (1 ratings)
vikram_anumukonda Fri, 03/06/2009 - 09:08
  • Bronze, 100 points or more
you can match the http (not https - as it is encrypted ) traffic based on the user-agent info from the http header ( i.e.., IE or FF) and then take an action like drop/log - But not sort.
Vikram
Correct Answer
vikram_anumukonda Fri, 03/06/2009 - 17:42
class-map WEB
parameters
log
parameters
log
class WEB
policy-map INSIDE
class WEB
inspect http ie
logging on
logging trap TEST
vikram
