IOS Upgrade
Mar 6th, 2009
Hello everyone,
I am trying to upgrade the IOS of 3750 Switch stack. I can upgrade the master, but the upgrade doesn't replicate to the other switches on the stack, and the switches start sending mismatch messages.
Any idea on how I can accomplished this task?
Overall Rating: 4 (1 ratings)
JamesLuther Fri, 03/06/2009 - 08:50
  • Silver, 250 points or more
If you've got the flash image up onto one of the switches you can manually copy it to the other switches using
copy flash1:/image.bin flash2:
copy flash1:/image.bin flash3:
etc
This is sometimes easier than using the automatic upgarde process
