7965 phone template
Mar 6th, 2009
I have a 7965 phone, I am new to my position and I was to know if there is a template that I can use to set this phone up on CM 5.1 or if I need to create a custon template for it.
Jaime Valencia Fri, 03/06/2009 - 10:01
  • Cisco Employee,
  • Hall of Fame,
    2011
if your server has support for a phone model a default template is already provided, if not what you need create one and customize it
java
if this helps, please rate
Rob Huffman Sun, 03/08/2009 - 11:44
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Carolyn,
Like Java nicely noted, if the 7965 is available as a choice when you look at "add a new phone" and under Device Defaults page then it will have a default phone button template. This will be populated when you add a 7965. If the 7965 is not shown in these two spots then we will have to look at how to add support for the 7965 via a new Device Pack addition to CUCM.
Let us know :)
Rob
