NonPOE device requesting POE?
Mar 6th, 2009
I'm having an issue with a Catalyst 3648 POE switch and a motorola wifi antenna. Essentially my logs get flooded with the errors below and eventually the switch shuts down the port because of flapping.
From what i can tell the device is not POE compliant and should not be requesting POE. I don't really understand enough about the POE standard to know how a request could be seen on the line (i.e. interference etc). Any ideas?
The lines have been verified with a Fluke meter, and yes doing a "power inline never" on the port fixes my issue, i'd just like it to work right :)
Mar 6 08:55:38.830 CST: %ILPOWER-7-DETECT: Interface Fa0/11: Power Device detected: IEE
E PD
Mar 6 08:55:38.830 CST: %ILPOWER-5-INVALID_IEEE_CLASS: Interface Fa0/11: has detected i
nvalid IEEE class: 7 device. Power denied
Mar 6 08:55:39.148 CST: %ILPOWER-7-DETECT: Interface Fa0/11: Power Device detected: IEE
E PD
Mar 6 08:55:39.148 CST: %ILPOWER-5-INVALID_IEEE_CLASS: Interface Fa0/11: has detected i
Mar 6 08:55:39.484 CST: %ILPOWER-7-DETECT: Interface Fa0/11: Power Device detected: IEE
E PD
Mar 6 08:55:39.484 CST: %ILPOWER-5-INVALID_IEEE_CLASS: Interface Fa0/11: has detected i
Mar 6 08:55:39.576 CST: %LINK-3-UPDOWN: Interface FastEthernet0/11, changed state to do
wn
Leo Laohoo Fri, 03/06/2009 - 16:24
Interface Fa0/11: has detected invalid IEEE class: 7 device.
Have you tried also to disable CDP on this interface?
thanmad Mon, 03/09/2009 - 09:39
Nope, haven't tried CDP disable, but the device on the other end is not CDP compatible...so...
