Cause of Sup720 failure and redudancy Sup720 failure
Mar 6th, 2009
Hi ,
I need the cause of failure in our Sup720 failure and the redudancy failure.
Please provide me the possible causes, so that i can take appropriate action to avoid the same failure in future.
I am attaching herewith the crashinfo (dir bootflash:) file.
Thank you.
Leo Laohoo Fri, 03/06/2009 - 16:16
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
The module in Slot 7 is failing. Try removing the blade in Slot 7 and see it this works.
Mar 1 06:03:35.623 EST: %FABRIC-SP-5-CLEAR_BLOCK: Clear block option is off for the fabric in slot 7.
Mar 1 06:03:57.371 EST: %FABRIC-SP-6-TIMEOUT_ERR: Fabric in slot 8 reported timeout error for channel 5 (Module 7, fabric connection 0)
Mar 1 06:04:00.511 EST: %OIR-SP-3-PWRCYCLE: Card in module 7, is being power-cycled off (Port asic not synchronized)
Mar 1 06:04:00.511 EST: %OIR-SP-3-PWRCYCLE: Card in module 7, is being power-cycled (OIR slot disable)
Hope this helps.
sivaprakasam81 Fri, 03/06/2009 - 19:27
Hi Leo,
It was resolved by reseating and reloading..., actually we want to know the cause of the issue. So that we will avoid such crash in future. Do you have any idea on this. Are you able to pick some info from the crash file.
1. Why the slot 7 (module 7) sup720 went down.
2. Why the Redudant one (module 8) sup720 also failed to take over.
Thanks you for your reply. Thanks again!!
