Historical Reporting Client
The Cisco Historical Reporting Client after install cannot connect to the database on the UC520 ? The error produced is "Failed to initialize any database connections. Check the log file for error 5066.  The log file does not show any error 5066 but it does tell me something is wrong with the node_id. The process gets past authentication and seems to fail at the node_id argument line 26.
See log:
1: 3/6/2009 12:28:21 PM %CHC-LOG_SUBFAC-7-UNK:Logging Init with: LogLevel=3 ,Max# LogFiles=10 ,Max Size Per LogFiles=1024000 Bytes
2: 3/6/2009 12:28:21 PM %CHC-LOG_SUBFAC-7-UNK:Log Files Path: 'C:\Program Files\Cisco Systems\CUCE Historical Reports\logs\'
3: 3/6/2009 12:28:21 PM %CHC-LOG_SUBFAC-7-UNK:Scheduler Root Directory Path: 'C:\Program Files\Cisco Systems\CUCE Historical Reports\scheduler\'
4: 3/6/2009 12:28:21 PM %CHC-LOG_SUBFAC-7-UNK:Scheduler Exports Directory Path: 'C:\Program Files\Cisco Systems\CUCE Historical Reports\reports\'
5: 3/6/2009 12:28:21 PM %CHC-LOG_SUBFAC-7-UNK:Scheduler SQL Files Directory Path: 'C:\Program Files\Cisco Systems\CUCE Historical Reports\scheduler\sql\'
6: 3/6/2009 12:28:21 PM %CHC-LOG_SUBFAC-7-UNK:Scheduler DB File Path: 'C:\Program Files\Cisco Systems\CUCE Historical Reports\scheduler\HistoricalReportScheduler.mdb'
7: 3/6/2009 12:28:21 PM %CHC-LOG_SUBFAC-7-UNK:Scheduler DB Provider: 'Microsoft.Jet.OLEDB.4.0'
8: 3/6/2009 12:28:22 PM %CHC-LOG_SUBFAC-7-UNK:CiscoAppReports7.0.1
9: 3/6/2009 12:28:22 PM %CHC-LOG_SUBFAC-7-UNK:Current Time Zone: Eastern Standard Time
10: 3/6/2009 12:28:22 PM %CHC-LOG_SUBFAC-7-UNK:Attempting to read commandline arguments
11: 3/6/2009 12:28:22 PM %CHC-LOG_SUBFAC-7-UNK:Commandline arguments received before parsing:
12: 3/6/2009 12:28:22 PM %CHC-LOG_SUBFAC-7-UNK:Ignoring all command line arguments
13: 3/6/2009 12:28:22 PM %CHC-LOG_SUBFAC-7-UNK:Arguments recieved are: Empty Array
14: 3/6/2009 12:28:24 PM %CHC-LOG_SUBFAC-4-UNK:'authRelUrl' key was not found in ini file (C:\Program Files\Cisco Systems\CUCE Historical Reports\hrcConfig.ini). Using default authentication relative URL /histRepWebSrvrComp/histRepClientsServlet
15: 3/6/2009 12:28:24 PM %CHC-LOG_SUBFAC-4-UNK:Form Login downloading info from URL(http://10.1.10.1/histRepWebSrvrComp/histRepClientsServlet)
16: 3/6/2009 12:28:24 PM %CHC-LOG_SUBFAC-7-UNK:http://10.1.10.1/histRepWebSrvrComp/histRepClientsServlet?usrid=cisco&pa...
17: 3/6/2009 12:28:24 PM %CHC-LOG_SUBFAC-7-UNK:Attempting to load XML response from authentication servlet
18: 3/6/2009 12:28:24 PM %CHC-LOG_SUBFAC-7-UNK:Successfully loaded XML response from authentication servlet
19: 3/6/2009 12:28:24 PM %CHC-LOG_SUBFAC-7-UNK:Attempting to read authentication result from XML response from authentication servlet
20: 3/6/2009 12:28:24 PM %CHC-LOG_SUBFAC-7-UNK:Recieved Successful authentication result from XML response from authentication servlet
21: 3/6/2009 12:28:25 PM %CHC-LOG_SUBFAC-7-UNK:Apps Server does not impose max connection restriction.
22: 3/6/2009 12:28:25 PM %CHC-LOG_SUBFAC-7-UNK:Obtained from Apps Server UID('hr_client') of 'CUE_DATABASE
23: 3/6/2009 12:28:25 PM %CHC-LOG_SUBFAC-7-UNK:Obtained from Apps Server SERVER('10.1.10.1') of 'CUE_DATABASE
24: 3/6/2009 12:28:25 PM %CHC-LOG_SUBFAC-7-UNK:Obtained from Apps Server DATABASE('hrdb') of 'CUE_DATABASE
25: 3/6/2009 12:28:25 PM %CHC-LOG_SUBFAC-7-UNK:Obtained from Apps Server NODE_ID('') of 'CUE_DATABASE
26: 3/6/2009 12:28:25 PM %CHC-LOG_SUBFAC-3-UNK: Error # 91 ,Description= Object variable or With block variable not set ,LastDllError= 0
27: 3/6/2009 12:28:25 PM %CHC-LOG_SUBFAC-3-UNK:Failed to login user to the apps server since we failed to initialize database connections
28: 3/6/2009 12:28:25 PM %CHC-LOG_SUBFAC-3-UNK:No Database Connections | Failed to initialize any database connections.  Check the log file for error 5066.
29: 3/6/2009 12:28:25 PM %CHC-LOG_SUBFAC-4-UNK:Application Exiting ...
1: 3/6/2009 2:42:00 PM %CHC-LOG_SUBFAC-7-UNK:Logging Init with: LogLevel=3 ,Max# LogFiles=10 ,Max Size Per LogFiles=1024000 Bytes
2: 3/6/2009 2:42:00 PM %CHC-LOG_SUBFAC-7-UNK:Log Files Path: 'C:\Program Files\Cisco Systems\CUCE Historical Reports\logs\'
3: 3/6/2009 2:42:00 PM %CHC-LOG_SUBFAC-7-UNK:Scheduler Root Directory Path: 'C:\Program Files\Cisco Systems\CUCE Historical Reports\scheduler\'
4: 3/6/2009 2:42:00 PM %CHC-LOG_SUBFAC-7-UNK:Scheduler Exports Directory Path: 'C:\Program Files\Cisco Systems\CUCE Historical Reports\reports\'
5: 3/6/2009 2:42:00 PM %CHC-LOG_SUBFAC-7-UNK:Scheduler SQL Files Directory Path: 'C:\Program Files\Cisco Systems\CUCE Historical Reports\scheduler\sql\'
6: 3/6/2009 2:42:00 PM %CHC-LOG_SUBFAC-7-UNK:Scheduler DB File Path: 'C:\Program Files\Cisco Systems\CUCE Historical Reports\scheduler\HistoricalReportScheduler.mdb'
7: 3/6/2009 2:42:00 PM %CHC-LOG_SUBFAC-7-UNK:Scheduler DB Provider: 'Microsoft.Jet.OLEDB.4.0'
8: 3/6/2009 2:42:01 PM %CHC-LOG_SUBFAC-7-UNK:CiscoAppReports7.0.1
9: 3/6/2009 2:42:01 PM %CHC-LOG_SUBFAC-7-UNK:Current Time Zone: Eastern Standard Time
10: 3/6/2009 2:42:01 PM %CHC-LOG_SUBFAC-7-UNK:Attempting to read commandline arguments
11: 3/6/2009 2:42:01 PM %CHC-LOG_SUBFAC-7-UNK:Commandline arguments received before parsing:
12: 3/6/2009 2:42:01 PM %CHC-LOG_SUBFAC-7-UNK:Ignoring all command line arguments
13: 3/6/2009 2:42:01 PM %CHC-LOG_SUBFAC-7-UNK:Arguments recieved are: Empty Array
14: 3/6/2009 2:42:04 PM %CHC-LOG_SUBFAC-4-UNK:'authRelUrl' key was not found in ini file (C:\Program Files\Cisco Systems\CUCE Historical Reports\hrcConfig.ini). Using default authentication relative URL /histRepWebSrvrComp/histRepClientsServlet
15: 3/6/2009 2:42:04 PM %CHC-LOG_SUBFAC-4-UNK:Form Login downloading info from URL(http://10.1.10.1/histRepWebSrvrComp/histRepClientsServlet)
16: 3/6/2009 2:42:04 PM %CHC-LOG_SUBFAC-7-UNK:http://10.1.10.1/histRepWebSrvrComp/histRepClientsServlet?usrid=cisco&pa...
17: 3/6/2009 2:42:05 PM %CHC-LOG_SUBFAC-7-UNK:Attempting to load XML response from authentication servlet
18: 3/6/2009 2:42:05 PM %CHC-LOG_SUBFAC-7-UNK:Successfully loaded XML response from authentication servlet
19: 3/6/2009 2:42:05 PM %CHC-LOG_SUBFAC-7-UNK:Attempting to read authentication result from XML response from authentication servlet
20: 3/6/2009 2:42:05 PM %CHC-LOG_SUBFAC-7-UNK:Recieved Successful authentication result from XML response from authentication servlet
21: 3/6/2009 2:42:05 PM %CHC-LOG_SUBFAC-7-UNK:Apps Server does not impose max connection restriction.
22: 3/6/2009 2:42:05 PM %CHC-LOG_SUBFAC-7-UNK:Obtained from Apps Server UID('hr_client') of 'CUE_DATABASE
23: 3/6/2009 2:42:05 PM %CHC-LOG_SUBFAC-7-UNK:Obtained from Apps Server SERVER('10.1.10.1') of 'CUE_DATABASE
24: 3/6/2009 2:42:05 PM %CHC-LOG_SUBFAC-7-UNK:Obtained from Apps Server DATABASE('hrdb') of 'CUE_DATABASE
25: 3/6/2009 2:42:05 PM %CHC-LOG_SUBFAC-7-UNK:Obtained from Apps Server NODE_ID('') of 'CUE_DATABASE
26: 3/6/2009 2:42:05 PM %CHC-LOG_SUBFAC-3-UNK: Error # 91 ,Description= Object variable or With block variable not set ,LastDllError= 0
27: 3/6/2009 2:42:05 PM %CHC-LOG_SUBFAC-3-UNK:Failed to login user to the apps server since we failed to initialize database connections
28: 3/6/2009 2:42:05 PM %CHC-LOG_SUBFAC-3-UNK:No Database Connections | Failed to initialize any database connections.  Check the log file for error 5066.
29: 3/6/2009 2:43:25 PM %CHC-LOG_SUBFAC-4-UNK:Application Exiting ...
What am I missing ?
Skyler Spence Mon, 03/09/2009 - 08:09
  • Bronze, 100 points or more
Have you tested to see if your database is configured correctly on CUE?  What does the output of show ccn reporting historical show?  Can you go into CUE and manually export reports to an FTP server?  This information can help determine where the error lies.
We have run the show ccn reporting historical command and here is the output. What we dont know is why the database usage is always 0%
Database Information
Enabled    : Yes
Description: mtsi
DB Usage: 0% (From last purge:Mon Mar 9  08:00:10)
Current Maintenance Status: idle
Purge Schedule
Daily Time: 8:00 AM
Data older than 5 days will be purged
Date of last completed purge: Mon Mar 9  08:00:10
Purge Capacity Configuration
Email Address:
Warning Capacity: 85%
Purge Capacity: 90%
Oldest Days to purge: 7
Yes I am able to ftp the file here is a snippet of the file output:
Expanded display is on.
3000000192,0,0,1,1,3,-1,A800113,2,-1,,2009-03-09 08:17:35.314,2009-03-09 08:17:35.314,-240,,,18000000192,0,ciscomwiapplication,0,EB2A94B4-011F-1000-4000-001125CUCE68,,,,,,,,,,
3000000193,0,0,1,1,3,-1,A800113,2,-1,,2009-03-09 08:17:59.17,2009-03-09 08:17:59.17,-240,,,18000000193,0,ciscomwiapplication,0,EB2AF1E4-011F-1000-4000-001125CUCE68,,,,,,,,,,
3000000194,0,0,1,1,3,-1,A800113,2,-1,,2009-03-09 08:18:16.565,2009-03-09 08:18:16.565,-240,,,18000000194,0,ciscomwiapplication,0,EB2B35D7-011F-1000-4000-001125CUCE68,,,,,,,,,,
3000000195,0,0,1,1,3,-1,A800113,2,-1,,2009-03-09 08:18:38.032,2009-03-09 08:18:38.032,-240,,,18000000195,0,ciscomwiapplication,0,EB2B89B2-011F-1000-4000-001125CUCE68,,,,,,,,,,
3000000196,0,0,1,1,3,-1,A800113,2,-1,,2009-03-09 08:18:58.442,2009-03-09 08:18:58.442,-240,,,18000000196,0,ciscomwiapplication,0,EB2BD96B-011F-1000-4000-001125CUCE68,,,,,,,,,,
3000000197,0,0,1,1,3,-1,A800113,2,-1,,2009-03-09 08:19:29.579,2009-03-09 08:19:29.579,-240,,,18000000197,0,ciscomwiapplication,0,EB2C5302-011F-1000-4000-001125CUCE68,,,,,,,,,,
3000000191,0,0,1,2,3,-1,113,2,-1,16906,2009-03-09 08:16:54.626,2009-03-09 08:19:48.047,-240,401,401,18000000191,2,voicemail,173,[email protected],,,,,,,,,,
3000000198,0,0,1,1,3,-1,A801113,2,-1,,2009-03-09 08:19:50.156,2009-03-09 08:19:50.156,-240,,,18000000198,0,ciscomwiapplication,0,EB2CA36C-011F-1000-4000-001125CUCE68,,,,,,,,,,
3000000199,0,0,1,1,3,-1,5089983374,2,-1,16902,2009-03-09 08:35:32.426,2009-03-09 08:35:41.135,-240,400,400,18000000199,3,autoattendant,8,[email protected],,,,,,,,,,
3000000200,0,0,1,2,3,-1,5089983374,2,-1,16900,2009-03-09 08:36:01.235,2009-03-09 08:36:52.109,-240,401,127,18000000200,2,voicemail,50,[email protected],,,,,,,,,,
3000000201,0,0,1,1,3,-1,A800127,2,-1,,2009-03-09 08:36:57.673,2009-03-09 08:36:57.673,-240,,,18000000201,0,ciscomwiapplication,0,EB3C512A-011F-1000-4000-001125CUCE68,,,,,,,,,,
3000000202,0,0,1,2,3,-1,127,2,-1,16896,2009-03-09 08:39:39.37,2009-03-09 08:40:39.40,-240,401,401,18000000202,2,voicemail,60,[email protected],,,,,,,,,,
3000000203,0,0,1,1,3,-1,A801127,2,-1,,2009-03-09 08:40:41.84,2009-03-09 08:40:41.84,-240,,,18000000203,0,ciscomwiapplication,0,EB3FBCC7-011F-1000-4000-001125CUCE68,,,,,,,,,,
3000000204,0,0,1,1,3,-1,5089983377,2,-1,16906,2009-03-09 08:48:16.394,2009-03-09 08:48:26.609,-240,400,400,18000000204,3,autoattendant,10,[email protected],,,,,,,,,,
3000000205,0,0,1,1,3,-1,4013749462,2,-1,16904,2009-03-09 08:56:53.772,2009-03-09 08:57:04.694,-240,400,400,18000000205,3,autoattendant,10,[email protected],,,,,,,,,,
3000000206,0,0,1,2,3,-1,117,2,-1,16902,2009-03-09 08:58:10.849,2009-03-09 09:00:22.759,-240,401,401,18000000206,2,voicemail,131,[email protected],,,,,,,,,,
3000000207,0,0,1,1,3,-1,A801117,2,-1,,2009-03-09 09:00:23.682,2009-03-09
Skyler Spence Mon, 03/09/2009 - 16:23
I noticed that my DB usage field is also not being updated correctly.  I'll look into this but since my client works fine I don't think the two problems are related.  Did you configure this in CLI as documented at http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel3_1/administr...   ?   What version of CUE is your system currently running, and are you sure that the client you downloaded is correct for that version?  The setup for this contains very few steps so we should be able to get to the bottom of this.
Running the latest version for the UC520 Version 3.2. We recently upgraded this UC520 to the latest download. I dont know for certain if I have the correct version of the client I installed 7.0.1. I have read the instructions several times and I felt they same way you did it should be pretty straight forward. I have feeling there is something not right with the latest versions working together ?
Skyler Spence Mon, 03/09/2009 - 20:21
The latest software pack includes CUE version 3.2.1, which is the version of the client that needs to be used.  You can find this version of the client here http://www.cisco.com/cgi-bin/tablebuild.pl/cue-321-utilities  It looks like you may have been using a client version that was one version higher than you need, try installing this other client and post your results.
Related Content
