UC520 volume for phones
Mar 6th, 2009
Hi again all. Im trying to help a customer out that has a UC520. They complain that the volume on the phones is low when trying to conference someone in. I have walked them through turning their volume up when offhook, but they say its still not loud enough. Is there a system control that I might be able to turn up for volume control in the UC520 config? Any help appreciated.
Overall Rating: 4 (2 ratings)
Nicholas Matthews Fri, 03/06/2009 - 12:00
  • Red, 2250 points or more
You may benefit from this command if it is specific to conferencing:
telephony-service
max-conferences gain 6
hth,
nick
jjoseph01 Fri, 03/06/2009 - 12:04
Ill try that out. Thanks for the help. Does that raise the volume up for conf?
Nicholas Matthews Fri, 03/06/2009 - 12:14
Yes, the gain is 6 dB, which is roughly twice as loud. dB's aren't linear, but an extra 3 dB roughly doubles the volume.
hth,
nick
robertdm1973 Mon, 03/09/2009 - 12:26
Thanks Nick, another good post.
What if the problem is on the ringback volume, which is low. Will this command be helpful?
My user is calling something like this:
PBX - fxo - GW - IP - GW - fxo - PBX
And the frequent complain is low volume for both voice and ringback.
Robert
Nicholas Matthews Mon, 03/09/2009 - 12:34
Hi Robert,
Here you can 4 different things.
On either of the 2 voice ports, you can set either of these settings:
voice-port 0/0/0
input gain
output attenuation -
So in this case you can make the voice louder by doing an 'input gain 5' on both voice ports. Or, you could do 'input gain 5' 'output attenuation -5' on one voice port.
The commands are just as how they sound - input gain raises the volume on incoming voice from the FXO, and output attenuation makes it quieter. In this case the attenuation is a negative value so it makes the output louder.
hth,
nick
robertdm1973 Mon, 03/09/2009 - 15:06
Hi Nick, this is helpful for voice but no significant effect on the ring back. The caller will still hear a 'muffled' ring.
Is there any command just for ringback tones?
Have seen this command but I think it's only for those not hearing any ringback at all:
progress_ind setup enable 3
Robert
Nicholas Matthews Mon, 03/09/2009 - 15:39
Hi Robert,
If these are FXO/FXS ports then there shouldn't be any difference between the ringback and normal voice. It's possible that the device generating ringback doesn't have a very loud ringback. I filed a bug on the Ringback from CUE on the UC520 but I don't think that's the case here.
I would try increasing the values to very high values and see if the ringback is improved at all. If not, then you may not have any other options.
-nick
