Failed in state 0 - error when booting with dual Sup 2
Mar 6th, 2009
Attempting to build a 6509 with Supervisor 2s in module 1 & 2 - OS is
CatOS 8.5.2.
When powered on with both sups in place, the system keeps repeating "Failed in stat 0" and will not start. We moved the modules to a 6506 and it booted properly.
The 6509 will boot with a single Supervisor 2 in module 1. We suspect a hardware issue with the chassis - is there anything we should check before opening a TAC case?
adamclarkuk_2 Fri, 03/06/2009 - 12:52
What happens when you boot with one installed, allow it to load, then insert the second module.
If it stays up, issue the command :-
show module 2
to get some more details.
marekenn1 Fri, 03/06/2009 - 13:11
We had tried that. The switch stayed up, but didn't see module 2 at all - not listed when we did "show module"
