Report Stopped Working
Mar 6th, 2009
I used to get the report "Activity: Spyware - Top Hosts". For the last few weeks the report shows nothing (no data). Any ideas on how to get this report populated again? I have rebooted MARS and that didn't help. Thanks
Farrukh Haroon Fri, 03/06/2009 - 23:07
  • Red, 2250 points or more
The first step would be to check if the reporting device is actually feeding this data into MARS? Have you verified that.
Farrukh
PaulWelc Mon, 03/09/2009 - 08:39
Hi Farrukh, I'm not sure what feeds this report, is there a way to tell? I have an IPS in my ASA, also have Active Directory sending reports to MARS.
Event type: Penetrate/Backdoor/Spyware/Response
Query Type: Source IPs ranked by Sessions
Time: 1d-0h
PaulWelc Tue, 03/10/2009 - 06:44
Farrukh, great idea, the only problem I chose to show me the report for a month, and for a year and MARS immediately comes back without data. I know I had data from the last year in this report( probably 3 months ago). I choose "Year" then click "display report" and 1 second later it comes back blank like it didn't try to pull the data.
Farrukh Haroon Tue, 03/10/2009 - 06:50
Can you logon to the CLI (SSH) and restart the MARS services? Usually MARS should make this large time-span query as a
'Batch Query' (and not inline), which would be delivered to your email inbox (if configured).
Farrukh
PaulWelc Tue, 03/10/2009 - 06:53
I can try this, though I did reboot MARS last week and still didn't get the report. I double checked my IPS module in my ASA to make sure it is sending alerts to MARS, it is. Thanks for all of your help!
