03-06-2009 11:20 PM - edited 03-04-2019 03:50 AM
Hi All,
We have 7200VX series router which has 4 port -PA 4T serial adapter.If we populate each port with an E1, then is possible to route all the bandwidth into the LAN through a single Ethernet port,or do we need 4 Ethernet ports.
Thanks in advance.
03-07-2009 12:00 AM
Hi Ravinder,
4x E1 lines have a bandwidth of 4x2048 kbits/s which is 8192 kbits/s (8.192 Mbits/s).
An Ethernet port has 10Mbits/s so it should be able to handle that traffic.
A problem may arise if the Ethernet port connects to a shared Ethernet segment saturated with traffic.
In this case the Ethernet port will not have its entire bandwidth available.
But if the Ethernet port connects to a switch with higher speed uplink ports then I think there should not be a problem.
Cheers:
Istvan
03-07-2009 12:25 AM
Hi Istvan,
Thank you very much for your reply.
If we connect the ethernet port to a Cisco 3500 Catalyst then we should not face any problem.?
I would also like to know how do we do routing in this case.we plan to use static routes.
03-07-2009 04:20 AM
Hello Ravinder,
it is very important to setup a 10 Mbps full-duplex link:
half-duplex supports up to 3.3 Mbps per direction.
So verify the ethernet port is capable of full-duplex I remember some PA with 4 Ethernet or 8 ethernet ports not capable of full-duplex operations.
Once this is solved you can use static routes
Hope to help
Giuseppe
