UNITY EXPRESS MODULE RESTARTING
Mar 7th, 2009
  • Bronze, 100 points or more
Its fresh 2821 router with NME-CUE module
showing this
MPORTANT::
IMPORTANT:: Administrator Account Creation
IMPORTANT::
IMPORTANT:: Create an administrator account. With this account,
IMPORTANT:: you can log in to the Cisco Unity Express GUI and
MONITOR SHUTDOWN...
IMPORTANT:: run the initialization wizard.
IMPORTANT::
Enter administrator user ID:
(user ID): admin
Failed creating admin
Reason: Error in DB operation : SQL Query error; nested exception is:
org.postgresql.util.PSQLException: The backend has broken the c
INIT: Sending processes the TERM signal (y/n)?
Restarting system.
show run is attached herewith
jconi Sat, 03/07/2009 - 13:44
It's an Hardware failure. I had the same problem with a new 2811 with a NME-CUE too. And when I made an RMA, I received an other NME-CUE with exactly the same problem !!!
The second RMA received was OK.
Maybe a recurrent problem with NME-CUE.
rgds
jp
Eldho E Kuriakose Sat, 03/07/2009 - 22:43
I have two routers, both of them having the same problem.....
ANY OTHER TROUBLESHOOTING SUGGESTION...
RELOAD UNITY OR WHAT????
jconi Tue, 03/10/2009 - 08:01
You can upgrade Unity Express through the Boot Loader, but I don't think it will solve the problem.
I also didn't believe I could have the same problem twice with 2 new modules. Open a TAC SR to confirm.
cmaiolani Sun, 03/22/2009 - 03:40
two days ago i had the same problem of reboot with NME-CUE in a 2821.
I resolved this issue with boot helper:
from version 3.2 i had upgraded it to version 7.0.2.
In this way i had successfully install my NME-CUE.
dany.datacraft Wed, 05/20/2009 - 07:49
Hi all,
I had the same problem with NME-CUE on 2851. I could recover by re-installing the software via boot helper, however, once the initial wizard completes, it gives the same error message again and keeps on rebooting non-stop.
Did anyone manage to get any answer from TAC? It seems to be a common problem with NME-CUE.
