Router product suguestion
Answered Question
Mar 7th, 2009
Hi, we have a internet connection delivered as a 100Mb Ethernet connected directly into our MS ISA FW. Dont know the actual speed but it amazing fast internet connection. Now we want better redundancy and the ISP offer us a secondary 100Mb connection connected to another core router in the ISPs backbone. But they tell us we need to have two routers that support VRRP and asymmetric routing. So i need to buy two routers and put those in front of our FW. Nothing else is required from the routers except deliver this functionality. I do not want to sacrifice speed but i have a limited budget, what Cisco product(s) should be a option for me?
Correct Answer by Leo Laohoo about 8 years 2 months ago
Have you tried looking at these PDF documents yet?
1. Portable Product Sheets - Routing Performance
http://www.cisco.com/web/partners/downloads/765/tools/quickreference/routerperformance.pdf
2. CISCO INTEGRATED SERVICE ROUTERS
http://www.cisco.com/web/partners/downloads/765/tools/quickreference/isr.pdf
Correct Answer by JamesLuther about 8 years 2 months ago
There are several design options you could go for here. It doesn't sound as if you have redundant ISA firewalls, so you need to ask do I need redundant routers?
Of course if you're buying redundant circuits then it makes sense to have 2 routers and 2 firewalls so you have full resiliency through the network path.
Anyway Cisco 1805 is a fairly low end router that will route traffic at 100MB. You could impliment one of these and plug both internet lines in the WAN side. On the LAN side plug in your ISA
Or you can buy two Cisco 1805 and use HSRP (better than VRRP) between the two routers. This would give you a more flexable design and enable to add redundany to your ISA in the future.
Overall Rating: 4.5 (3 ratings)
Correct Answer
JamesLuther Sun, 03/08/2009 - 09:36
  • Silver, 250 points or more
larsselegran Mon, 03/09/2009 - 04:16
Hi, yes your are right redundant FW makes sense also, and will be implemented later. For now we just start implementing two routers outside of the ISA. Will look into the 1805 router. Thx
Correct Answer
Leo Laohoo Mon, 03/09/2009 - 15:40
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Leo Laohoo Tue, 03/10/2009 - 14:24
  • Hall of Fame,
    2017 LAN, Wireless
Thanks for the rating.
