Router Selection
Answered Question
Mar 7th, 2009
What is a good router to use for an organization of 200 people?
Correct Answer by Richard Burts about 8 years 1 month ago
George
For an office supporting 200 people and with a T1 as its link to outside I would probably suggest a router in the 1800 series, perhaps the 1841 which comes with 2 FastEthernet interfaces and a slot in which you can install a card for a T1. This router would have the capacity to route over the T1 and to do routing within the office.
Rick
Overall Rating: 5 (1 ratings)
adamclarkuk_2 Sat, 03/07/2009 - 12:26
  • Silver, 250 points or more
Unfortunately, we are going to need more information than that to recommend a router.
1. What do you need the router to be able to do
2. What kind of throughput are you expecting
3. If this is an edge device, what type of Internet connection do you have
rayroyaleverest Sat, 03/07/2009 - 13:06
The router will be used in a small office. The Internet connection will be T-1. I don't know what the throughput will be.
Correct Answer
Richard Burts Sat, 03/07/2009 - 15:22
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
George
Rick
