Help me understand a NAT/VPN issue
Answered Question
Mar 7th, 2009
Hello all,
I've stumbled upon something that I cannot explain and I could use some help in order to understand what is happening :)
The problem, as I see it, is as follows (in short terms):
My router seems to do NAT on the return packets on an incoming connection that arrives via the VPN connection. This only happens to packets that are using ports that I have forwarded using ip nat inside source static...
I am using nat exempt for the VPN connections. The NAT exempts are working just fine except when they seem to "collide" with port forwardings.
This translation entry is listed after i try to telnet from a 10.0.0.x host to 10.45.131.23 port 80:
Cisco_1811#sh ip nat t | inc 10.0.0.
tcp 172.16.0.64:80 10.45.131.23:80 10.0.0.6:1872 10.0.0.6:1872
How can I make the router not do NAT at all on the VPN connections?
I'm suspecting it's because I'm using route-map instead of lists in the NAT overload statement.
P.S.
The router has 172.16.0.64 as its "public" ip and the config is attached to this message.
Correct Answer by Yudong Wu about 8 years 1 month ago
You can try to add a route-map which will deny all VPN related traffic on all static nat entries.
ip nat inside source static tcp 1.1.1.1 80 2.2.2.2 80 route-map xxx
By the way, It seems your vpn config is incomplete. I did not see pre-share key and peer ip are configured.
Overall Rating: 5 (1 ratings)
Correct Answer
Yudong Wu Sat, 03/07/2009 - 19:04
  • Gold, 750 points or more
jesper_petersen Fri, 06/18/2010 - 04:19
Hi kwu2
Just wanted to thank you. You were correct
And for others in the same sitaution here is a link to a blog that describes the problem and fix.
http://www.ciskoblog.com/2008/02/static-nat-inac.html
