Internal eigrp ,external eigrp
Answered Question
Mar 7th, 2009
  • Bronze, 100 points or more
Hi everybody!
I have few questions about eigrp.
My book says eigrp(internal) has AD=90
and eigrp(external) has AD=170
what is external eigrp?
thanks a lot!
Correct Answer by Jon Marshall about 8 years 3 months ago
Actually a better setup would be
ra (192.168.1.1/30) -> EIGRP -> (192.168.1.2/30) rb -> (192.168.2.1/30) IGRP -> (192.168.2.2/30) rd
ra
int s0
ip address 192.168.1.1 255.255.255.252
int loopback10
ip address 210.210.210.1 255.255.255.0
router eigrp 1
network 192.168.1.0
network 210.210.210.0
no auto-summary
rb
int s0
ip address 192.168.1.2 255.255.255.252
int s1
ip address 192.168.2.1 255.255.255.252
router eigrp 1
network 192.168.1.0
no auto-summary
router igrp 1
network 192.168.2.0
no auto-summary
rd
int s1
ip address 192.168.2.2 255.255.255.252
int loopback10
ip address 180.180.180.1 255.255.255.0
router igrp 1
network 192.168.2.0
network 180.180.180.0
no auto-summary
Jon
Sarah
For automatic redistribution to work you need to run the same AS for EIGRP and IGRP on the SAME router. So in your case what you are seeing is correct.
Try this on rd
interface Ethernet0
ip address 199.199.199.4 255.255.255.0
interface Serial0
ip address 200.200.200.4 255.255.255.0
interface Serial1
ip address 201.201.201.4 255.255.255.0
router eigrp 1
network 199.199.199.0
router igrp 1
network 200.200.200.0
network 201.201.201.0
What you should then see is the 199.199.199.0 network should appear on ra and rb.
Jon
Correct Answer by Richard Burts about 8 years 3 months ago
Perhaps we need to be careful about exactly what the book says and the context in which it says it. It has been quite a while since I have used IGRP but my memory is that redistribution was not automatic. But what was automatic was the metric used.
In general when you redistribute into EIGRP or IGRP you need to specify a default metric since the metrics in IGRP/EIGRP are not compatible with metrics of other protocols and there is not an automatic default metric (as there is in OSPF for example). But the metrics of IGRP and of EIGRP are compatible (not the same but compatible) and so if you configure redistribution between an IGRP process and an EIGRP process then there is no requirement to specify a default metric.
Perhaps you can describe exactly how you set up your test and what you did observe in the test?
Rick
Zeeshan
An EIGRP external route is a route that was redistributed into EIGRP.
If the route was learned from a network statement then it is internal. And if it was learned from redistribution then it is external.
Rick
Overall Rating: 5 (4 ratings)
Correct Answer
Richard Burts Sat, 03/07/2009 - 15:13
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Zeeshan
Rick
sarahr202 Sat, 03/07/2009 - 15:26
Hi Rick!
if you don't mind could you explain the following:
My book says auto redistribution occurs between igrp and eigrp if they have same AS.
However, when i performed a lab i did not find any auto matic redistribution between igrp and eigrp having same AS.
thanks a lot!
Correct Answer
Richard Burts Sat, 03/07/2009 - 15:35
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Rick
sarahr202 Sat, 03/07/2009 - 16:30
I will run the test again and post the output tomorrow . You guys have a good weekend!
thanks a lot!
sarahr202 Sun, 03/08/2009 - 08:58
Hi every body!
Here is my lab set up.
Three routers( 2500 series), rb,ra,rd are connected in triangular fashion.
ra is connected to rd via s1(200.200.200.1)
ra is connected to rb via s0 (202.202.202.1
rb is connected to ra via s0,202.202.202.2
rb is connected to rd via s1 201.201.201.2
rd is connected to rb via s1 201.201.201.4
rd is connected to ra via s0 , 200.200.200.4
please view the attached file for configurations.
Correct Answer
Jon Marshall Sun, 03/08/2009 - 09:40
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Sarah
Try this on rd
interface Ethernet0
interface Serial0
interface Serial1
router eigrp 1
router igrp 1
Jon
sarahr202 Sun, 03/08/2009 - 10:16
Thanks jon! Very much indeed 199.199.199.0 appeared in routing tables on ra and rb.
Thanks and have a nice weekend!
Correct Answer
Jon Marshall Sun, 03/08/2009 - 09:49
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
ra
int s0
int loopback10
router eigrp 1
network 192.168.1.0
no auto-summary
rb
int s0
int s1
router eigrp 1
network 192.168.1.0
no auto-summary
router igrp 1
network 192.168.2.0
no auto-summary
rd
int s1
int loopback10
router igrp 1
network 192.168.2.0
no auto-summary
Jon
