ICND2 Commands Related to Topics / Cliff Notes
Mar 7th, 2009
Does a resource exist that simply has only the required commands for the ICND2 exam. What I mean by this is a list of commands or examples for configuration that map directly to the ICND2 exam objectives. I am 99% comftorable with the theory and concepts behind ICND2, I'm just lacking when it comes to memorization of the commands, and I'd like to practice.
I know a cisco command pocket guide exists, but so many commands are given in that resource that it makes it difficult to use as a exam study resource. What I need is a command guide that only lists configuration examples that directly relate to the exam objectives.
For example: Frame Relay ~
config t
int s0/1/0
encapsulation frame-relay
no shut
frame-relay map ip 192.168.1.2 102 broadcast
