static nat
Mar 7th, 2009
  • Gold, 750 points or more
A customer has two sites connected via a metro-e link. They are requesting that a video conference unit at the remote site utilize a public ip address. The video traffic comes into the main site and then crosses the metro-e to the video unit. Will the following command take care of it.
ip nat inside source static 10.x.x.229 63.x.x.229
Thank you in advance!
Overall Rating: 5 (1 ratings)
Yudong Wu Sat, 03/07/2009 - 21:08
The command will configure a static NAT entry which map the internal/local IP 10.x.x.229 to external/global IP 63.x.x.229. If this is what you wnats, the answer is "yes". You also need configure "ip nat outside" and "ip nat inside" under related interface.
