CUCM 6.X - VmWare Memory Requirement
Mar 7th, 2009
Hi there,
I just installed a CUCM 6.x on a VmWarare and it's seems to works fine except....
From another PC, I access it by web and it is so slow.. It's pretty much if I can't login because it's too slow.
What are the physical memory requirement on the PC that I've install the Vm to run CUCM.
thanks a lot
david-lima Sun, 03/08/2009 - 10:51
  • Bronze, 100 points or more
Hi Phil, just as a reference, I have a PC core2duo with 3 GB og RAM and 250GB of HD, for my lab, CUCM 6.0 is running on the VMWare with 2GB RAM and 72GB of HD and it is working fine.
Best regards
David
philippe.cousineau Mon, 03/09/2009 - 07:32
ok, I'm running an old 800 mgz with 512 of ram, I guess it's normal if I can't access the CCM Web page, well I can access it but when I login it's too slow
esmoreno Mon, 03/09/2009 - 07:36
I got it working smoothly with 1GB.
Esteban
Justin Brenton Mon, 03/09/2009 - 15:29
  • Silver, 250 points or more
Hi Philippe,
What OS are you running? Have you thought of running Linux?
Linux would run this more smoothly then windows will especially with so little ram.
I would set the OS as linux and install VMWare Server. Load the VMWare Image. Back online.
or
Upgrade your ram to atleast 1gb. Set your pagefille to 1.5 GB min and 1.5 max with the Windows OS as this will help in stoping your windows os in pagefile allocation.
HTH, Please Rate
Justin
Justin Brenton Mon, 03/09/2009 - 15:33
I have CUCM, Unity, AD/Exchange, IPCC on a single server running Linux OpenSuse 11/VMware Server.
I also have dual boot on this pc with Windows and Linux and have tested both OS's. Linux is much smoother in response. The MOH on the windows OS is choppy when I place a call on hold, with Linux it's clear as can be.
Justin
