MSTP instance 0 and 1
Mar 7th, 2009
I have a question regarding a topology of 3 switches :
1. When i configure cisco switch 3750 IOS(12.2) to work with MSTP instance 0 , is it mean that i work RSTP ? or MSTP ?
2.Why i needed to define portfast for fast convergence to the Host ports for Instance 0 (otherwise convegence time was 30 sec)
but when i configured the switch instance 1 i did not have to do so.
The convegence time was less than 1 sec ?
Giuseppe Larosa Sun, 03/08/2009 - 00:26
  • Hall of Fame,
    Founding Member
Hello Yoram,
1) MST 802.1s supports multiple RSTP 802.1W instances
2) In RSTP it is very important to define the edge ports (with spanning-tree portfast) in order to improve convergence time: each edge port is excluded from the handshake and sync process it is not an optional part.
see
http://www.cisco.com/en/US/tech/tk389/tk621/technologies_white_paper09186a0080094cfa.shtml#edge
3)
Actually MST doesn't send out distinct BPDUs for each instance: a single set of BPDUs is sent out with sections about other instances.
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_44_se/configuration/guide/swmstp.html#wp1039828
Hope to help
Giuseppe
yoram12345 Sun, 03/08/2009 - 01:26
hi Giuseppe,
Thanks for the info.
Actually i would like to test interop between cisco MSTP to other switch RSTP.
So teh question is if i should define the vlan on CISCO on instance 0 or different than 0 ?
Or it does not matter.
Yoram
Giuseppe Larosa Sun, 03/08/2009 - 06:03
  • Hall of Fame,
    Founding Member
Hello Yoram,
I report here a link to a thread with an answer from Francois Tallet one of greatest experts in STP in the forums :
see
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Network%20Infrastructure&topic=LAN%2C%20Switching%20and%20Routing&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40^1%40%40.1dde86cf/5#selected_message
It should be fine with instance 0, and probably also with instance 1
Hope to help
Giuseppe
