In DFM,all devices went to question state
Mar 7th, 2009
Dear all,
we are using ciscoworks lms 3.0 in our company.
In moring ciscoworks 10 process when down (i.e SyslogAnalyzer, CTMJrmServer, DFMCTMStartup, DataPurge, ChangeAudit, ConfigMgmtServer, ICServer, EssentialsDM, TomcatMonitor, RMEOGSServer).
All devices in DFM when on qestion state. when i want to rediscover it all went on learning state and from past 2 days it is in learning state and half devices again went to question state.
IN common services, device discovery is taking long time to find devices . Before it used to take maximum half an hour and known it is taking more than four to five hours.
I restarted the process again . all are woking known,but the problem still presist.
plese help me to sought this problem.
thanks,
ashraf
Overall Rating: 5 (1 ratings)
Joe Clarke Sat, 03/07/2009 - 23:13
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You are seeing two known bugs in DFM 3.0. Both are fixed in DFM 3.0.4. If you currently have DFM 3.0.0, you will need to upgrade to LMS 3.0.1 which will include DFM 3.0.2. From there you can download DFM 3.0.4 from Common Services > Software Center > Software Update.
You can download LMS 3.0.1 from http://www.cisco.com/cgi-bin/tablebuild.pl/lms301 .
