unable to get IP address from DHCP
Mar 7th, 2009
hi all,
I have a AP1131 which cannot get IP from DHCP server. I have tried to configure static IP address and controller IP by lwapp command and the AP can successfully joined the controller. However, after I changed it to DHCP in WLC, it cannot get IP address and all lwapp config is gone. It cannot join the controller anymore only after I reset it and configure a static IP for it. The following error message appears after I changed it to DHCP in the WLC:
*Mar 7 08:44:36.511: RESETTING THE STATIC IP ADDRESS: LWAPP goes back to discovery
%WIDS-6-DISABLED: IDS Signature is removed and disabled.
%LWAPP-5-CHANGED: LWAPP changed state to DISCOVERY
%LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
%LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
%LWAPP-3-CLIENTERRORLOG: Config Command: error verifying sequence number
%LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
%LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
Any expert has some idea on it?
Thanks.
George Stefanick Sun, 03/08/2009 - 06:34
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, October 2015
Do you have IP Helper set on the router?
frances.lau Sun, 03/08/2009 - 06:36
yes, i have other APs working properly on the network but only one AP has this problem.
Scott Fella Mon, 03/09/2009 - 08:33
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
Is that AP on the same subnet as the other AP's? The thing is, when you configure the AP with static information, you say the AP is able to join the WLC. This means that there is no issue with the AP. Now when you set the AP to use DHCP and not static, the AP does not obtain a DHCP address? Is that correct? If you have more than one AP on the same switch and on the same vlan, and only one has an issue, then maybe reset that AP to default and see if that fixes it. I'm also assuming that the vlan is being forwarded and you have enough dhcp address in the scope.
Leo Laohoo Mon, 03/09/2009 - 15:00
  • Hall of Fame,
    2017 LAN, Wireless
Is this AP on the same VLAN as the rest of your AP?
frances.lau Mon, 03/09/2009 - 18:00
it is in the same vlan of another AP. actually, i already tried to reset it, convert it to IOS and convert it back to lwapp mode again but the situation is the same.
Scott Fella Mon, 03/09/2009 - 18:03
  • Hall of Fame,
    2017 Wireless
Do you have other ap's on the same switch with the ap that is not working.
Scott Fella Mon, 03/09/2009 - 18:08
  • Hall of Fame,
    2017 Wireless
Do you have the one set correctly on the wlc? If you reboot one of the other ap's, will that obtain a dhcp?
frances.lau Mon, 03/09/2009 - 18:09
yes, it is set correctly on WLC. other AP still obtain IP address even after reboot.
Scott Fella Mon, 03/09/2009 - 18:14
  • Hall of Fame,
    2017 Wireless
I would open a TAC case... Maybe they will rma your ap if determined bad. Never had an ap that I can set as a static that couldn't obtain a dhcp address. You are not doing mac reservation for dhcp.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
