03-08-2009 12:23 AM - edited 03-11-2019 08:01 AM
Can this be done? I have a Webserver and another server on the inside on two different Vlans and I want them to be accessible from both ISP links inbound. I keep getting the following message:
Here is what I have for the first two and it works.
static (VLAN3,Outside1) 63.139.165.45 192.168.175.85 netmask 255.255.255.255 dns
static (VLAN3,Outside0) 66.209.123.13 192.168.175.85 netmask 255.255.255.255 dns
when I add these two - it gives the message at the bottom
static (VLAN2,Outside1) 63.139.165.45 192.168.170.85 netmask 255.255.255.255 dns
static (VLAN2,Outside0) 66.209.123.13 192.168.170.85 netmask 255.255.255.255 dns
WARNING: mapped-address conflict with existing static
VLAN3:192.168.175.85 to Outside1:63.139.165.45 netmask 255.255.255.255
VLAN3:192.168.175.85 to Outside0:66.209.123.13 netmask 255.255.255.255
03-08-2009 12:39 AM
This doesnt work either - Any Ideas?
static (VLAN3,Outside1) tcp 63.139.165.45 www 192.168.175.85 www netmask 255.255.255.255 dns
static (VLAN3,Outside0) tcp 66.209.123.13 https 192.168.175.85 https netmask 255.255.255.255 dns
static (VLAN2,Outside1) tcp 63.139.165.45 www 192.168.170.85 www netmask 255.255.255.255 dns
static (VLAN2,Outside0) tcp 66.209.123.13 https 192.168.170.85 https netmask 255.255.255.255 dns
03-09-2009 08:16 AM
you cannot use 2 times the same TCP/UDP port for different internal server.
When a packet from outside reaches the asa, the asa tries to forward the packet and has 2 possible internal destinations. Which should the asa use? => This can't work!
Regards, Celio
03-09-2009 01:38 PM
Is there any other way?
03-12-2009 05:44 AM
Hello Jerry,
You might want to check the below post
