OS X 10.5.x L2TP/IPSEC VPN Client + ASA 5505
I'm trying to get Apple's l2tp/ipsec client to function with an ASA. I've successfully connected with Cisco's client, with the desired access to the remote subnet, but as soon as I add this command:
crypto ipsec transform-set TUNNEL_ESP_3DES_SHA mode transport
the Cisco client can no longer connect.
Once the transform set is set to transport mode, the apple client can connect, but it can't see any of the remote LAN resources. Heres the config:
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ip address w.x.y.z 255.255.255.252
access-list SPLIT extended permit ip 192.168.1.0 255.255.255.0 192.168.150.0 255.255.255.0
access-list NONAT extended permit ip 192.168.1.0 255.255.255.0 192.168.150.0 255.255.255.0
ip local pool ra_ip_pool 192.168.150.1-192.168.150.254 mask 255.255.255.0
global (outside) 1 interface
nat (inside) 0 access-list NONAT
nat (inside) 1 0.0.0.0 0.0.0.0
route outside 0.0.0.0 0.0.0.0 w.x.y.z 1
crypto ipsec transform-set TUNNEL_ESP_3DES_SHA esp-3des esp-sha-hmac
crypto dynamic-map client-crypto-map 40 set transform-set TUNNEL_ESP_3DES_SHA
crypto map cm-client-ra-vpn 20 ipsec-isakmp dynamic client-crypto-map
crypto map cm-client-ra-vpn interface outside
crypto isakmp identity address
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp nat-traversal 3600
client-update enable
dhcpd auto_config outside
dhcpd address 192.168.1.2-192.168.1.33 inside
dhcpd enable inside
group-policy client_ra_vpn_gp internal
group-policy client_ra_vpn_gp attributes
vpn-tunnel-protocol IPSec l2tp-ipsec
split-tunnel-policy tunnelspecified
split-tunnel-network-list value SPLIT
tunnel-group DefaultRAGroup general-attributes
address-pool ra_ip_pool
default-group-policy client_ra_vpn_gp
tunnel-group DefaultRAGroup ipsec-attributes
pre-shared-key *
tunnel-group DefaultRAGroup ppp-attributes
authentication ms-chap-v2
tunnel-group client_ra_vpn_tg type ipsec-ra
tunnel-group client_ra_vpn_tg general-attributes
tunnel-group client_ra_vpn_tg ipsec-attributes
pre-shared-key *
tunnel-group client_ra_vpn_tg ppp-attributes
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 2048
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect pptp
service-policy global_policy global
JamesLuther Sun, 03/08/2009 - 05:39
  • Silver, 250 points or more
Have yo tried adding both configs with different sequence numbers? ie
crypto ipsec transform-set CISCO_CLIENT esp-3des esp-sha-hmac
crypto ipsec transform-set APPLE_CLIENT esp-3des esp-sha-hmac
crypto ipsec transform-set APPLE_CLIENT mode transport
crypto dynamic-map client-crypto-map 40 set transform-set CISCO_CLIENT
crypto dynamic-map client-crypto-map 50 set transform-set APPLE_CLIENT
I added the 2nd config, Cisco client still works, apple client doesn't. Just to retest, I added mode transport to CISCO_CLIENT without changing anything else, and sure enough, apple client can connect but no traffic passes.
I then tried simply changing the order in the crypto dynamic-map, and whichever is first in sequence is successful, the other fails. Still no traffic when apple client connects.
Looking at debug messages during Apple client failure, Phase 1 is successful, Phase 2 reports "All IPSec SA proposals found unacceptable"
nicolas.scheffer Sat, 05/09/2009 - 06:04
I have a similar problem with ASA 5510 running 8.2(1) but same with 8.0.4(31) :
- iPhone using IPSEC works on ASA 5510
- no way to setup the ASA for iPhone and Mac using L2TP over IPSEC
Any ideas ?
Failure is after Phase 1 where i have :
- All IPSec SA proposals found unacceptable!
- QM FSM error (P2 struct &0xd9c86038, mess id 0x9e07a9fa)!
Thnaks for any help!
Nicolas
nicolas.scheffer Sat, 05/09/2009 - 23:39
I made some progress!
Now i have a failure after Phase 2 for L2TP when i try from the Mac or iPhone using L2TP but the iPhone using the built-in Cisco IPSec client continu to working.
Here is some debugs regarding the L2TP Access :
May 10 09:32:14 IKEv1: IP = 82.246.31.188, IKE_DECODE RECEIVED Message (msgid=dcaebe4c) with payloads : HDR + HASH (8) + NONE (0) total length : 52
May 10 09:32:14 IKEv1 DEBUG: Group = DefaultRAGroup, IP = 82.246.31.188, processing hash payload
May 10 09:32:14 IKEv1 DEBUG: Group = DefaultRAGroup, IP = 82.246.31.188, loading all IPSEC SAs
May 10 09:32:14 IKEv1 DEBUG: Group = DefaultRAGroup, IP = 82.246.31.188, Generating Quick Mode Key!
May 10 09:32:14 IKEv1 DEBUG: Group = DefaultRAGroup, IP = 82.246.31.188, NP encrypt rule look up for crypto map outside_dyn_map 1 matching ACL Unknown: returned cs_id=d9cd7b18; rule=00000000
May 10 09:32:14 IKEv1: Group = DefaultRAGroup, IP = 82.246.31.188, Security negotiation complete for User () Responder, Inbound SPI = 0xfa085ca6, Outbound SPI = 0x0e1fc739
May 10 09:32:14 IKEv1 DEBUG: Group = DefaultRAGroup, IP = 82.246.31.188, IKE got a KEY_ADD msg for SA: SPI = 0x0e1fc739
May 10 09:32:14 IKEv1 DEBUG: Group = DefaultRAGroup, IP = 82.246.31.188, Pitcher: received KEY_UPDATE, spi 0xfa085ca6
May 10 09:32:14 IKEv1 DEBUG: Group = DefaultRAGroup, IP = 82.246.31.188, Starting P2 rekey timer: 3420 seconds.
May 10 09:32:14 IKEv1: Group = DefaultRAGroup, IP = 82.246.31.188, PHASE 2 COMPLETED (msgid=dcaebe4c)
May 10 09:32:14 IKEv1: IKEQM_Active() Add L2TP classification rules: ip <82.246.31.188> mask <0xFFFFFFFF> port <36755>
L2TP LOWERLAYER: l2tp_add_classification_rules()...ip <82.246.31.188> mask <255.255.255.255> port <36755>
L2TP LOWERLAYER: l2tp_add_fw_rule(): If 1, peer IP 82.246.31.188, peer port 36755
L2TP LOWERLAYER: np_classify_add_static(PERMIT) vpif_num<1> np_rule_id <0xd77b18c0>
L2TP LOWERLAYER: l2tp_add_punt_rule(): If 1, peer IP 82.246.31.188, peer port 36755
L2TP LOWERLAYER: np_classify_add_static(PUNT) vpif_num<1> np_rule_id <0xd7b50c50>
L2TP LOWERLAYER: l2tp_punt_service_callback() ch:<0xd5a95140>, flow:<0x27321bf2> inVpifNum<1:outside> outVpifNum<0:NP Identity Ifc>
L2TP PACKET: vPifNum:<1> proto saddr<82.246.31.188> daddr<91.199.0.68> sport<36755> dport<1701>
L2TP PACKET:
dest_ip <82.246.31.188>, dest_port <36755>, ipsec_ident<0x9a000>, vPifNum <1:outside>, channel: <0xd5a95180>
L2TP LOWERLAYER: PUNT CONSUMED!
May 10 09:32:16 IKEv1 DEBUG: Group = DefaultRAGroup, IP = 82.246.31.188, IKE SA MM:8c279c79 rcv'd Terminate: state MM_ACTIVE flags 0x00010042, refcnt 1, tuncnt 1
May 10 09:32:16 IKEv1 DEBUG: Group = DefaultRAGroup, IP = 82.246.31.188, sending delete/delete with reason message
May 10 09:32:16 IKEv1 DEBUG: Group = DefaultRAGroup, IP = 82.246.31.188, constructing blank hash payload
May 10 09:32:16 IKEv1 DEBUG: Group = DefaultRAGroup, IP = 82.246.31.188, constructing IPSec delete payload
May 10 09:32:16 IKEv1 DEBUG: Group = DefaultRAGroup, IP = 82.246.31.188, constructing qm hash payload
May 10 09:32:16 IKEv1: IP = 82.246.31.188, IKE_DECODE SENDING Message (msgid=ac044337) with payloads : HDR + HASH (8) + DELETE (12) + NONE
I read somewhere on the Cisco Site that L2TP must use default Group and Policy which is not possible for me. If it's correct i don't know how to solve this!
Nicolas
nicolas.scheffer Mon, 05/11/2009 - 00:01
It works!!!
You just need to disable all ms-chap-vx and enable pap only under ppp-attributes
Nicolas
