aaa new-model
cisco_lite
If i define aaa new-model (i.e. to use local username/password) and password under vty configuration, which one would be applicable while doing ssh into the router/switch.
Thanks.
adamclarkuk_2
Level 4
Level 4
It goes under vty, you just need to allow the transport
Line vty 0 4
Transport input ssh telnet
Then create the user under global conf
Username blah password blah
Does it mean if username is defined, ssh/telnet would not refer to password under vty.
It depends on that you have set the aaa authentication to look at. If you use the command :-
aaa authentication login default line
then it will look at the line password (username can be anything), but the default will want a username and password and will not use the password under the vty details.
With the command:-
aaa authentication login default local line
It will try the line password first (username can be anything) if that fails it tries to match a username and password in the local database.
