3560 POE issues
Answered Question
Mar 8th, 2009
Hi Guys
i have a 3560 running IOS 'c3560-ipservices-mz.122-25.SEB4.bin'
When i connect a cicso ip phone into the port it goes into err-disable. when i do a show power inline f0/19 it says inline power is not supported on this interface. This is the case for all interfaces...
The power available is showing as zero.. why is this?
I checked the feature navigator and it seems as though this hardware and IOS should support poe, anyone got any ideas??
Switch#sho power inline
Available:0.0(w) Used:0.0(w) Remaining:0.0(w)
Interface Admin Oper Power Device Class Max
(Watts)
Switch#
Switch#sho power inline f0/19
Interface Fa0/19: inline power not supported
Correct Answer by adamclarkuk_2 about 7 years 10 months ago
The 3560 does support POE but not every model.
What is the model of your 3560
Below is a link to the 3560's with and without POE support :-
hxxp://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps5528/product_data_...
Overall Rating: 5 (1 ratings)
andretimoll Sun, 03/08/2009 - 10:47
WS-C3560-24TS-E
Looking at the data sheet it does not support poe.
Thanks for clearing this up.
