getting delay in recieving pstn calls
Mar 8th, 2009
Good Morning!!!
Today i had an issue with my voice network. Its queit strange to me and it is higly appreciated if someone can help me.
let me explain my problem. ... It was too delay while reciving PSTN call to my Voice network. But after few minutes ( around 15 minutes) it was restored back to normal. We didnt find any log even we checked in our gateways. Can some help us..
regards
amritpatek Sun, 03/15/2009 - 15:00
  • Silver, 250 points or more
On IOS voice gateways, if you experience a delay in the call setup as this document describes, you can configure the timeouts interdigit seconds command on the voice ports. This applies only to the voice ports that have this command configured, so you need to apply it to all ports that experience the issue. This command output provides an example that shows this configuration:
AUSNML-3725-02#configure terminal
Enter configuration commands, one per line. End with CNTL/Z.
AUSNML-3725-02(config)#voice-port 2/0/1
AUSNML-3725-02(config-voiceport)#timeouts interdigit 3
