What IOS version is best
Answered Question
Mar 8th, 2009
Folks, I took an older 2621 and upgraded the ram & flash. I inserted a AIM vpn card. I now want to upgrade the IOS so the AIM card shows up in my config. Ill be doing site to site ipsec VPNS...Which one do you guys recommend?
Correct Answer by adamclarkuk_2 about 7 years 10 months ago
This should give you what you need (and a little more) :-
12.3(26)
Feature set/License IP/FW/IDS PLUS IPSEC 3DES BASIC
c2600-ik9o3s3-mz.123-26
Minimum DRAM = 64
Minimum Flash = 16
btw, you can find out what ios you need using the software advisor (CCO login needed)
hxxp://tools.cisco.com/Support/Fusion/FusionHome.do
Overall Rating: 5 (1 ratings)
adamclarkuk_2 Sun, 03/08/2009 - 14:58
What have you upgraded the RAM and Flash to and is the the XM series ?
Also which AIM-VPN is it EP/BP
Correct Answer
adamclarkuk_2 Mon, 03/09/2009 - 02:21
12.3(26)
Minimum DRAM = 64
Minimum Flash = 16
