03-08-2009 03:43 PM - edited 03-06-2019 04:28 AM
I'm attemtping to setup a small lab.
I have one 3550 SMI
I have several VLANs defined, see config below. I have a DHCP server - 10.10.10.2
And a route to the rest of the network via 192.168.0.90.
From the switch, I can ping the VLAN interfaces (as long as there's a device on the VLAN). Howver, there are two problems:
1- DHCP doesn't work, the discovery never makes it to the server
2. I'm unable to ping clients (which are statically addressed) in the other VLANS.
The routing table looks correct.
From the switch I can ping the outside world.
My config is attached.
I would sincerely appreciate any help.
Solved! Go to Solution.
03-08-2009 07:35 PM
Hector,
This is clearly a L2 issue. Where are the server and client connected. I only see 3 access port in vlan1010 (fa0/2,fa0/3,fa0/4) and these 3 ports are down in the output you provided. fa0/1 is a trunk port and carries vlan 1010. Are the server and client connected to another switch? If so, is the trunk port up?
03-08-2009 04:09 PM
Okay, your "sh ip route" does not show a directly connected route for 10.10.10.x. This i suspect is why you can't ping the DHCP server.
Can you post output of "sh ip int brief"
Jon
03-08-2009 06:04 PM
Jon, thanks for the fast response, see below. I seem to have a route to VLAN 1010, which has an IP of 10.10.10.10.
And, I confirmed that each client uses its respective VLAN IP as the Default Gway. Thanks again.!
meru#sho ip interface brief
Vlan1 10.10.1.1 YES manual up down
Vlan192 192.168.0.90 YES manual up down
Vlan1010 10.10.10.10 YES manual up down
Vlan1020 10.10.20.10 YES manual up up
Vlan1030 10.10.30.10 YES manual up up
Vlan1040 10.10.40.10 YES manual up down
FastEthernet0/1 unassigned YES unset down down
FastEthernet0/2 unassigned YES unset down down
FastEthernet0/3 unassigned YES unset down down
FastEthernet0/4 unassigned YES unset down down
FastEthernet0/5 unassigned YES unset up up
FastEthernet0/6 unassigned YES unset down down
FastEthernet0/7 unassigned YES unset down down
FastEthernet0/8 unassigned YES unset down down
FastEthernet0/9 unassigned YES unset down down
FastEthernet0/10 unassigned YES unset down down
FastEthernet0/11 unassigned YES unset up up
FastEthernet0/12 unassigned YES unset down down
FastEthernet0/13 unassigned YES unset down down
FastEthernet0/14 unassigned YES unset down down
FastEthernet0/15 unassigned YES unset down down
FastEthernet0/16 unassigned YES unset down down
FastEthernet0/17 unassigned YES unset down down
FastEthernet0/18 unassigned YES unset down down
FastEthernet0/19 unassigned YES unset down down
FastEthernet0/20 unassigned YES unset down down
FastEthernet0/21 unassigned YES unset down down
FastEthernet0/22 unassigned YES unset down down
FastEthernet0/23 unassigned YES unset down down
FastEthernet0/24 unassigned YES unset down down
GigabitEthernet0/1 unassigned YES unset down down
GigabitEthernet0/2 unassigned YES unset down down
03-08-2009 06:18 PM
Vlan 1010 (where the dhcp server is supposedly attached) does not look like it is up so the server would not be able to be reached. In your routing table there is also no connected route for vlan 1010 because it is up/down. What you posted is not the route table it is a interface listing , there is no route for 10.10.10.X in the route table. As far as clients i would check things like make sure the windows firewall is turned off . Make sure all the gateways on the clients point to the correct SVI address on the 3550 for the given vlan they are attached to. Note below what you posted , there is no route for 10.10.10.X because the SVI for 1010 is in a up/down state.
10.0.0.0/24 is subnetted, 3 subnets
C 10.10.20.0 is directly connected, Vlan1020
C 10.10.30.0 is directly connected, Vlan1030
C 10.10.40.0 is directly connected, Vlan1040
C 192.168.0.0/24 is directly connected, Vlan192
S* 0.0.0.0/0 [1/0] via 192.168.0.1
meru#ping 4.2.2.1
03-08-2009 06:30 PM
Thanks Glen. Below is an updated routing table and interface status. This all looks good. Except, I see my VLAN 1 is down, don't kwno why. Again, any ideas are appreciated.
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is 192.168.0.1 to network 0.0.0.0
10.0.0.0/24 is subnetted, 4 subnets
C 10.10.10.0 is directly connected, Vlan1010
Vlan192 192.168.0.90 YES manual up up
Vlan1010 10.10.10.10 YES manual up up
Vlan1040 10.10.40.10 YES manual up up
03-08-2009 06:57 PM
Some more details:
I put a PC (10.10.10.13) in VALN 1010, with the DHCP server(10.10.10.2), the PC obtains an IP address via DHCP.
Pings from client to server -- work
Pings form server to slient -- work
Pings from client to def. gway 10.10.10.10) -- fail
Pings from server to def. gway (10.10.10.10) -- fail
pings from router to client 10.10.10.13 fail
pings from router to server 10.10.10.2 fail
pings from router to 10.10.10.10-- work
03-08-2009 07:35 PM
Hector,
03-08-2009 07:58 PM
My bad, it was a simple addressing issue on one of the clients. I can now ping from / to everywhere.
Now on to my next challenge -- DHCP
I've setup IP Helper addresses on each VLAN, all pointing to the DHCP server 10.10.10.2 which is in VLAN 1010. However, the only client to obtain an address is the client in the same VLAN (1010) as the DHCP server.
I've turned on a sniffer on the DHCP server, the only DHCP traffic is see is that which comes from VLAN 1010.
IP UDP debugs on the router show the broadcasts with no reply.
Any suggestions?
03-09-2009 05:28 AM
Hector,
The issue could be that the defaut gateway is not set on the DHCP server.
03-09-2009 07:48 AM
In a separate post Hector described his problem with DHCP and then updated it to explain that he solved the problem with DHCP when he enabled service dhcp.
Rick
03-09-2009 08:09 AM
Thanks for the heads-up Rick.
