How to access my Voice mail from PSTN
Mar 8th, 2009
Dear All,
I have CUCM version 6.0 integrated with Unity 5.0 , I need your support for the configuration steps I need to do to be the users can access his voice mail from PSTN, I need a detail configuration I will do on the CUCM and unity.
Thanks ,
Ahmed Ellboudy
Jaime Valencia Sun, 03/08/2009 - 21:13
simply have something route you to unity from PSTN (translation pattern, CTI RP with CFA to VM whatever you like) then press * to reach sign in
or configure a routing rule to go direct to sign in
java
if this helps, please rate
ahmed_ellboudy Tue, 03/10/2009 - 02:44
Dear java ,
I made CTI RP with CFA to VM and I configured a routing rule as attached ,but still I can not get my voice mail, if you see any mistake please advice .
Thanks ,
Ahmed Ellboudy.
Jaime Valencia Tue, 03/10/2009 - 07:31
yes 2 errors
this is not a direct call, use forward rules not direct rules
configure DNIS, not ANI
change those and try again, i assume the DN from screenshoot is the one from CTI RP because that's supposed to be the DNIS
java
ahmed_ellboudy Sun, 03/15/2009 - 02:39
Dear Java,
Thanks for your greet support , I made it and it is working now.
Ahmed Ellboudy.
