IP Helper DHCP Assistance Needed
I have one 3550 configured with serveral vlans. ip routing is setup between all vlans. I have a windows 2003 dhcp server which I want to serve all vlans.
the server is in vlan 1010 with IP 10.10.10.2. problem is only the client that's in the same vlan is able to receive an address. I also have clients in vlan 1020 and 1030.
I've double-checked the config on the DHCP server. Each scope has it's respective VLAN IP configured as the gateway.
when I turn on debug IP UDP, then relese /renew the affected client(s), I see UDP 67/68 packets, but that's all.
Richard Burts Sun, 03/08/2009 - 21:44
Hector
I am glad that you figured out the solution to your own problem. Thank you for posting back to the forum indicating that you had solved it and what the problem was. It makes the forum more useful when people can read about a problem and can read what the problem was and what solved it.
Rick
