Battery replacement.
Answered Question
Mar 9th, 2009
l.s.
I suspect one of my controllers to have a faulty battery which has to be replaced, in the pricing tool i cannot find a replacement part number.
can anyone enlighten me on where to find this?
Thanx in advance
Frans Verschoor
Correct Answer by jeff.kish about 8 years 1 month ago
Hi Frans,
I'm sorry, I thought you meant some kind of internal battery for device operation. It certainly does have a BIOS battery of some kind.
Do you have NTP configured, or do you just have the time hard-set?
There won't be a part number for this kind of thing. You'll need to use a SmartNet contract to open a Cisco TAC case. They'll be able to assist you with this.
Jeff
Overall Rating: 5 (1 ratings)
jeff.kish Mon, 03/09/2009 - 07:05
  • Silver, 250 points or more
Do you mean a faulty power supply? Or maybe a device other than a controller? The reason I ask is that controllers don't have batteries.
snarf65 Mon, 03/09/2009 - 07:12
No not the power supply that's fine, i mean maybe something like a biostypelike battery to keep the internal clock running. are you sure they don't have one. In this case i'm working with a 3750 integrated 4402 controller.
and this particular one loses it's set time whenever it is rebooted.
Greetings Frans
Correct Answer
jeff.kish Mon, 03/09/2009 - 07:28
Hi Frans,
Jeff
snarf65 Mon, 03/09/2009 - 08:19
i have ntp configured, and all my other controllers have no problem retaining time (in between the configured update windows oc.) thanx i'll be contacting our service partner for this.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
