OSPF routing is not working properly.
Mar 9th, 2009
1. router-2 is head office router.
2. router-1 is one location directly connected with leased line.
3. ospf routing is not working.thats why default routing is used in the configuration(find attachment).
4. Show command result of router-1 is shown in attachmnet.
kindly help me in this mattaer so that i can use my ospf configuration with out defualt routing.
Siddhartha
Giuseppe Larosa Mon, 03/09/2009 - 03:44
  • Hall of Fame,
    Founding Member
Hello Siddharta,
you need to decide if you want to have OSPF running only on the GRE tunnel you need to remove the network command con the ip subnet of the serial link.
In fact you have:
network 10.10.54.0 0.0.0.255 area 0
that is the WAN interface to HQ
network 192.168.10.0 0.0.0.255 area 0
on R2 router under ospf I don't see the
there is
network 192.168.0.0 0.0.0.255 area 0
and
I would do the following changes
remove on both routers
add on R2
this creates an OSPF adj on the GRE tunnel.
Otherwise you could risk negative effects in having ospf enabled on both the GRE logical link and the physical link
to troubleshoot OSPF adjacencies you can use:
terminal monitor
debug ip ospf adj
Hope to help
Giuseppe
