3750E sh int - output drop incoherent display
Mar 9th, 2009
I use the command "show interface" to display the interface's stats on my Core swith (WS-C3750E-48PD-EF in 12.2(35r)SE1) and the display is completly incoherent ???
First with 0 output drops
and after 43489 output drops
then 0 output drop again
and this in few seconds ?
Is there a bug on the display ?
This symptom is the same others interfaces.
Joseph W. Doherty Mon, 03/09/2009 - 05:13
Agreed, it sure doesn't look correct.
If you have maintenance, since you're 3750E is running 12.2(44)SE1, you might first try 12.2(44)SE5. (NB: the 12.2(35r)SE1 is the boot software.) Or, if you have maintenance, something to bring to TAC.
