Remove file
Answered Question
Mar 9th, 2009
Hi There,
I created a scritp that records a message and send it by e-mail.. (voicemail script) .. it's working fine..
But I notice that the recorded files were not removed from server.
How can I remove them ? Is there any step that I missed ?
Thanks.
Andrei.
Correct Answer by villarrealed about 7 years 10 months ago
Andrei,
When you use the Write step in your script, it will write to the file system on the server. Remove this Write step and it will not keep the document on the server, it will only keep the wav file in memory.
Overall Rating: 5 (1 ratings)
Correct Answer
villarrealed Mon, 03/09/2009 - 09:56
Andrei,
