Upgrade from 5.1.2a to 5.1.3d
Mar 9th, 2009
Problem Details: Hello,
I have few doubts about an upgrade from 5.1.2.2000-3 (5.1.2a) to 5.13d .
I have a costumer with that version ( 650 ip telephones and cisco unity 4.1).
I must know few things :
1. The telephone firmware (actual version ) is compatible with the new version 5.1.3d?
2.Before install 5.1.3d i need to install version 5.1.3 ? Is not possible to install only
one version?
I need the documentation and a solution for upgrading the firmaware telephones ( models
7941,7911,7961,7914,7936,cisco ata 186 and 7985 )and ccm as soon as possible with any
failures.
I attach you the actual firmware version
Thanks.
Jaime Valencia Mon, 03/09/2009 - 08:48
  • Cisco Employee,
  • Hall of Fame,
    2011
1 it should be compatible, but new version might come with a newer FW and phone will upgrade
2 of course you do, you cannot do this in one step. a patch is exactly that, a patch for some version. if you don't have the base version how could you patch it??????
FW upgrade is done via OS admin -> upgrades
instructions are in README or RN
java
if this helps, please rate
