Added ACS server in MARS
Mar 9th, 2009
i want to add ACS server in MARS . is there any other configuration in ACS Server to add into MARS or just add in it.
Overall Rating: 5 (1 ratings)
David Levy Thu, 03/19/2009 - 10:50
Why not just configure ACS to send syslogs to MARS. That way you do not need the agent.
rottenberg Fri, 03/27/2009 - 05:25
There are two main versions of ACS 3x and 4x. According to documentation (bkDcgMars.pdf for MARS 6.x) you should use pnAgent for ACS 3x with Cisco Secure ACS 3.x as reporting application in MARS and with ACS 4.x you should configure syslog client in ACS (Systeme Configuration->Logging) and use Cisco Secure ACS 4.x as reporting application in MARS.
According to my own experiences with MARS 6.0.1 ( 3066 ) and ACS 4.2(0) Build 124 Patch 8 only pnAgent variant worked for me. (I used pnAgent on ACS and Cisco Secure ACS 3.x as reporting application on MARS).
Excuse my Englis.
