interface continues to go up / down
Mar 9th, 2009
I have a question concerning a Cat 3750.
Presently, I have a couple VLAN's configured on this LAN switch. We only have 1 user on the switch (planned for many more). I have the following VLAN's configured:
VLAN 200 managment
VLAN 201 User VLAN
I have an up link to an aggregation switch via a layer 3 PO (PO3)
My problem is this.
If the single user removes his desktop from the switch, the VLAN Interface goes into an Up / Down state until such time as a host is plugged back into the switch.
any thought on why this would be?
Richard Burts Mon, 03/09/2009 - 07:28
It is the expected behavior of the switch that if a VLAN has no active device connected (or is not connected to an active trunk) that the VLAN will go to a down state. Over time, as you get more users connected to the VLAN this issue should take care of itself.
s.marino Mon, 03/09/2009 - 08:33
Do you have this user port set as:
switchport mode access
spanning-tree portfast
or is it set to the defaults out of the box?
I also agree with Rick.
