Jon Marshall Mon, 03/09/2009 - 08:48
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
David
If the WAN presents as ethernet then yes you can do this. You would look to connect a switch into the LAN ethernet on the 2811 and then you can route the LAN from the 2811.
If you are going to need a number of internal vlans then you can either
1) use 802.1q subinterfaces on the 2811 ethernet interface to route between the vlans and connect the switch to the 2811 as a trunk port
OR
2) use a L3 switch such as the 3560/3750 and route between vlans on the switch and then connect the switch to the 2811 router with a L3 routed link.
Jon
