Callmanager Express 4.1
Mar 9th, 2009
Dear All,
I have CallManager Express 4.1, I want to configure one of my extensions (701) to automatically forward the calls to another extension (705) after 2 rings only if no body there to pick the handset of 701
How to do this?
rob.huffman Mon, 03/09/2009 - 07:08
Hi Majai,
call-forward noan
To configure call forwarding so that incoming calls to an extension (ephone-dn) that does not answer are forwarded to another number, use the call-forward noan command in ephone-dn or ephone-dn-template configuration mode. To disable call forwarding, use the no form of this command.
call-forward noan target-number timeout seconds
timeout seconds - Sets the duration that a call can ring with no answer before the call is forwarded to the target number. Range is from 3 to 60000. There is no default value.
From this good CME doc;
Hope this helps!
tonyspcrepairs Tue, 03/10/2009 - 05:43
I am only a beginner but in your config try this:
#ephone-dn 701
call-forward noan 705 timeout 4
you might need to save the running-config and reboot the router to bring in the change.
Adrian Saavedra Tue, 03/10/2009 - 07:02
Hi Anthony,
Rebooting the router is not necessary for changes to take effect.
Best regards,
- Adrián.
