03-09-2009 07:11 AM - edited 03-11-2019 08:02 AM
All-
What is this message I see in the fws log?
[ Scanning] drop rate-1 exceeded.
Vlad
Solved! Go to Solution.
03-09-2009 02:04 PM
By the way "scanning drop" includes:
ACL drop, Bad packet drop, Conn limit drop, ICMP drop, Inspect drop, Interface drop and Syn attack.
03-09-2009 01:57 PM
Please check the following link for the explannation.
http://www.cisco.com/en/US/docs/security/asa/asa80/system/message/logmsgs.html#wp4963969
03-09-2009 02:04 PM
03-10-2009 06:21 AM
is there a way I can check what hosts were previously shunned if now I cant see any.
I have the log which says rate exceeded but I want to see which were the shunned hosts.
I cant see any with sh threat-detection shun
V
02-17-2012 07:01 AM
I'm receiving the same messages on log:
[ Scanning] drop rate-1 exceeded. Current burst rate is 10 per second, max configured rate is 10; Current average rate is 9 per second, max configured rate is 5; Cumulative total count is 5622 |
[ Scanning] drop rate-2 exceeded. Current burst rate is 8 per second, max configured rate is 8; Current average rate is 8 per second, max configured rate is 4; Cumulative total count is 31781
It happens all the time. It doesn't show the source or destination. I'm using ASDM 6.1 - ASA 5510 How can I avoid this messagens and protect from this scanning attacks? Thank's, Renato |
02-17-2012 11:31 AM
Found Solution for drop rate-1:
https://supportforums.cisco.com/thread/228276
The syslogs "[ Scanning] drop rate-1 exceeded." mean the you have exceeded the "Scanning attack detected" threshold.
Shows a threshold that you exceeded.
But threat detection will not drop unless you tell it to.
The default behavior is to just alert (generate syslog).
So I would like to know if drop rate-2 is the same.
Thank's.
