Phone Firmware Load
Answered Question
Mar 9th, 2009
Sorry for asking a question that has most likely already been asked, but I can't find it in my search. How do I get the phones in Call Manager 5.1 to take the firmware load after I apply a firmware upgrade to the system? I can see my new firmware in the device defaults section, but the phones are still all on the old firmware even after a reset. Any insight that anyone can offer would be greatly appreciated as I can't think of much else to try on my end.
Steve
Steve
Correct Answer by Rob Huffman about 8 years 1 month ago
Hi Steve,
Did you Stop/Start the TFTP Sevice?
Hope this helps!
Rob
Overall Rating: 5 (2 ratings)
Correct Answer
Rob Huffman Mon, 03/09/2009 - 07:23
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Steve,
Hope this helps!
Rob
slongewa Mon, 03/09/2009 - 07:40
I forgot to restart the TFTP service. This took care of the issue.
Thanks Rob!
Steffen.Baier Mon, 03/09/2009 - 07:28
Did you just upload a new FW to the TFTP?
If yes you need to change the Device Defaults Configuration within the device settings and update it with the details of the new FW.
You then reset the phones and they will load the new Firmware.
You can do the same to single phones within their device details in order to test it on some phones only.
Steffen
