Performance - ASA 5550/5580 versus Nokia IP560/590
Mar 9th, 2009
I've just been looking at the performance stats for the firewalls we have (Nokia) and the firewalls we are planning to get (ASA) and found the following:
Nokia IP560
FW - large packets 6.0 Gbps
VPN - large packets 1.78 Gbps, AES256
CPS - 58,000 CPS
Max 725,000 FW TCP sessions
Nokia IP690
Firewall - large packets 7 Gbps
VPN - large packets 1.85 Gbps, AES256
Max TCP 725,000
TCP session rate 35,624
Cisco ASA 5550
Maximum firewall and IPS throughput(Mbps)1.2 Gbps
Maximum firewall connections 650,000
Maximum firewall connections/second 36,000
Packets per second (64 byte)600,000
Maximum 3DES/AES VPN throughput 425 Mbps
Maximum site-to-site and remote access VPN sessions 5000
Maximum SSL VPN user sessions 5000
Bundled SSL VPN user session 2
Either Nokia and Cisco are measuring completely differently, or the ASA is way, way slower than the Nokia boxes
Can anyone help?
Many thanks
JamesLuther Mon, 03/09/2009 - 12:23
If you look at the 5580 then your able to get upto 20 Gbps (using large packet sizes) and 2 million concurrent connections.
This competes well with a Nokia box.
